| I have installed thousands of rear farm tires in the years I was in the farm tire business. Part of these guys are right. Forget about ANY type of dish soap to mount rear tractor tires. It ISN'T slick enough. Anyone who tells you it is--is not a tire professional . get your self some real rubber lube. Napa stuff is OK, but there are far slicker products out there. Any farm tire store should have a gallon they will sell. Good luck. Did you get the rim on straight. I have straightened up quite a few and tried to straighten a lot more that had a permant wave in them because they were bolted on and really horsed down without being straight on the hub. If you checked it - did you check it for side to side wobble and up and down wobble. If you didn't you need to. Again Good Luck.
Edited by hd6gtom 7/23/2017 16:40
