Southeast IN | I have not had any problem back feeding power to my control system. Im using a Trimble Field IQ system. With a generic harness lead on my Deere 4700 sprayer. Winterizing is a bit of a problem. If you leave the switch on to keep the valve open the battery will be run down. If you close the valve freezing can bust the valve. Two solutions I have used is unplug the harness with the valves open or just make sure you have enough antifreeze in the boom.
Edited by JD8520 2/20/2021 13:31
