Near Intersection of I-35 & I-90 Southern Mn. | Thanks for the reply. I had thought about the idea of physically swapping the suspicious ECU with either of my other two as they do not exhibit the problem and have never failed. If the problem follows then I would know the problem is with THAT ECU. As the troublesome one is in the planting tractor it is the most important one.
As I've mentioned before once I get past the startup phase, it works very well and I don't have any problem until possibly the next cold start. |
