East Central Saskatchewan | Ah you guys get all worked up over lock washers, eventually you get to the point and just weld them dam fricken nuts down and then weld the bolt head down and be done with it ;), especially my son if he gets mad from something going loose he just torques as quoted "The f*n son of a b*ch ain't comin loose now" as I see a handful of snapped and stripped bolts on the ground and the item now has four half inch bolts in it with double flat washer on both sides and triple lock nut when originally it had and only needed on quarter inch bolt with a lock nut. |
