Posted 11/24/2014 13:34 (#4198596 - in reply to #4198586) Subject: RE: I'm not quite sure why eveyone seems to pooh-pooh the idea of running corn less than 2mph.....
NEIN
Given the same combine box, the one using a wider header will at the end of the day do more because of fewer turns and passes across the field. The amount going thru the machine is not set by the header but rather by the threshing capacity of the machine. Its called efficiency, fact not feeling.
