Near Intersection of I-35 & I-90 Southern Mn. | Concerning the STTM. I have one but have not had need to swap it out. I will be moving the planter tractor today and can look at the planting configuration to see which modules have serial numbers listed. This will be for our satisfaction as I'm sure most could care less as long as it works.
The planter is a ground drive 1770NT CCS. I have the SC-110 CAN switch box, a Clutch Control Module, STTM, single Liquid Module, Application Rate Module, and down force monitoring. I found S.N. listed for the single Liquid Module and the Application Rate Module which surprises me since it will only recognize one anyway. None of the other devices seems to have a S.N. listed but I was not connected to the planter which I don't think should matter.
Edited by tedbear 8/2/2020 12:20
