Posted 7/23/2017 07:59 (#6143549 - in reply to #6143516) Subject: RE: 4450 alternator / volt meter
Missouri
They can get weak, but it's not necessarily the alternator.
First, I would find your poor connection. .4 volts drop from the alternator to the battery is excessive. Also 13.2 volts at the alternator is a little low. It should be closer to 14 or a little over, unless the alternator is really hot, or the engine speed really low.
