Search Forums | Classifieds (23) | Skins | Language
Intregra moisture problem in corn
GKW
Posted 10/6/2020 17:00 (#8533150)
Subject: Intregra moisture problem in corn
West Central Iowa
Ever since I installed this Integra in combine for moisture on corn ive had a problem On the range of moisture on corn! Ex if I have 20, 24, 28 per corn in the same field! I can sample an cal on 24 corn and the range will only change from 23-25 per. I can cal for 24 corn and then to get to a corn that’s 20 and it won’t go below 23 unless I cal again for the dryer corn. I used a pf 3000 before and the moisture range would always change. It works great on soybeans showing ranges from 10-16. Just a problem on corn! Clean out auger is always working! Let me know if there are any other setting in the grain setup! Thanks
