Pressure washer for milking parlor
Brown Cow
Posted 9/14/2020 14:37 (#8495338 - in reply to #8494782)
Subject: RE: Pressure washer for milking parlor
SW Wisconsin
You may have already done this, but check with your inspector. Here they want to be sure you have a check valve on the input, in case the pump pulls too much water and you get negative pressure on your water line.
