Posted 10/26/2018 11:49 (#7066528 - in reply to #7062574) Subject: RE: Are there Terrastar C problems right now?
Geuda Springs, Kansas
I think you need to setup the auto steer. The reason I say this is because even if not using autosteer the gps data is corrected with the tilt sensors through the steer command or ontrac controller. It simply looks like your tilt or x y z axis is not set correctly.
