Posted 12/7/2008 16:19 (#526860 - in reply to #526840) Subject: Re: Possible alternative to Tru-Count or Row Command...
N IL
Sounds interesting. So basically you would shut off vac pressure and then it would drop the seeds from the plate but the disk would still turn?
Sounds like it might work but after it goes to turn it back on, how long will it take to get the disk full again? Is there going to be a gap until it starts to plant again?
Where as once the clutch is turned back on it starts planting right away.
