| I have that same wiring harness you are looking for on order now from my dealer as our new 1790 didnt come with it. I is just a short harness that connects to the convience outlet for constant power to the planter. Thaught about wiring up my own cause only one wire is used in it and it goes to constant power as i found one on the neighbors tractor and did some diagnosing of my own. I was out in pa when we took delivery so when it comes time to get it ready im learing i dont have all i need to make it work . You should have a harness right in front of the planter on the tounge to hook up the compressor and thats where ours is mounted with a tank behind the ccs tanks. Also a filter in the cab and only adjusted with the gs2 seedstar 2 screen. | |
