Search Forums | Classifieds (124) | Skins | Language
AutoPilot, 332, Insight 8120 ILS
tedbear
Posted 5/13/2006 10:44 (#11908 - in reply to #11465)
Subject: Another thought about interference
I have a second cable attached to Port B of the 332 which could go to another GPS device.
This is the standard Trimble Data cable with power. At the time I was planting corn and had the Noisy 1 PPC faults, this cable was plugged into Port B but not hooked to power or a GPS device. Port A was supplying the power and outputting the GPS to the Nav Controller and eventually the Insight.
On a Trimble, power and ground IN can be supplied by either port. By testing I found that if power is supplied via Port A that Power is available on the cable attached to Port B. I'm wondering if this "loose" cable could be a acting as an antenna of sorts and allow "Noise" in.
The simple solution of course is to just un plug it from Port B as I'm not using it for anything at this time.
