SW Illinois | 3700 doesn't flex much. only one flex point in center. Its good enough for 95% of our ground, and is marginal on the other 5%, but gets it done. If you were just planting and nothing else it is my favorite 24, simple and light. I remember pulling one with a JD 4955, but it was tricky. Not sure if it would work how your setting it up.
I'm not sure how well a 3600 can tow a cart, but the frame is good and maneuverable. if only using for corn, should be plenty heavy enough frame for any attachments. | |
