E.Central MN | 93" wide/100 hp. So you need at least 96" wide snowblower. You might be on the short end of hp for that. It depends on the depth of the snow, the capacity of the snowblower or how well you can match the speed with the capacity of the snowblower. If you have slow enough gears it will work ok. I run an 8' single auger snowblower with about 90 hp, but it has a mechanical transmission with a very low range. We have bigger tractors that are powershift but the reverse speed is too fast for the capacity of the snowblower that we have. | |
