From the Fill-Rite website:
https://www.fillrite.com/ProductCatalog/1532.pdf Scrolling down to the Pump specs, it is not even 35 gpm open flow; just 34.3!!! When I studied rounding-off in math, this spec would be 34 gpm. The pump, as supplied with hose and nozzle, puts out 28.7 gpm. Like other posters have said, your biggest flow restriction is the 2 micron filter. You will have to decide if you want higher flow, or very good filtration. |
