Posted 11/3/2018 11:09 (#7081538 - in reply to #7081492) Subject: RE: Which Timble drive? EZ, EZ Pro, Autopilot Motor Drive
NW KS
I am not sure how the pricing structure works on the GFX-750 but I will try to explain the different steering options. The ez-pilot would be the lowest option out of the systems listed. Online performance is decent but it isn't as aggressive to return to the guidance line as the systems listed. Autopilot motor drive and autopilot are fairly similar with the key difference being that the autopilot motor drive uses an electric motor to turn the steering wheel but the autopilot uses the hydraulic valve. Performance between the two system is very similar. Sounds like you might be using the system at extremely slow speeds through and I don't have any experience with that. At typical operating seeds for most equipment though I can't tell any difference between an autopilot and autopilot motor drive.
