Eastern Washington | That wont work... (as a rain gauge inch of rain, depends on the opening at the top of the gauge and the scale on the side.... it will not match the Vue, for the amount of water you pour in)..
As was stated, you can use the offset feature and change the cal... also as was said, wind and surroundings can make a small difference.
I believe, I was told (by Davis) that if you pour in 10cc of water, it should read I think it was .10 inches. | |
