Classifieds (37)
How do you convert dry feed values to wet feed value?
Stock Talk
jc1206
4/18/2018 15:36 (#6717633)
northern IL
How would you compare dry gluten feed at $150 per ton to 55% moisture feed at $50 per ton?
If I took the difference between 55% and 15% or 40% and used it this way am I correct?
$50÷40%=$125
Or
$150 × 40%=$60
Is there a shrink factor involved also?
How much less lbs of dry would you feed compared to wet also?
jc1206
: 4/18/2018 15:36
RE: How do you convert dry feed values to wet feed value?
Beefbiz
: 4/18/2018 16:08
cjd12000
: 4/18/2018 16:17
Re. The power of $1 per point of DM-ya i think different
garvo
: 4/18/2018 19:28
