Thanks for the info, though I'm not sure what all you said yet. I'll figure it out. I don't know if 640x480 is good enough. I want to be able to see & hear a continuous flow dryer. I should be able to see if the load auger is running, I guess. I should be able to hear air unload system. I assume camera will be about 50' away from dryer, mounted 20' in the air. The area will be well-light @ night. I assume you're saying I can have multiple cameras on this site (dryer) & select their view remotely from another computer thru a website? What are you using your setup for? You can email me if you'd rather. Thanks |
