Posted 7/16/2006 17:35 (#27147 - in reply to #27038) Subject: RE: 2388 combine low on power, Any ideas?
Caraway, AR
My 2188 did the same thing. Heres what I did.
There is a hex plug on the back side of the aneroid body. Take it out and you will see a star wheel shaped adjuster similar to a brake adjuster. Screw this wheel all the way down, or until there is slack in the spring.
Next replace the supply pump. An easy change and about 120.00$$
