| If you are planting anything that maybe wet hydraulic drive is nice-no slip, just keeps planting. Getting the hydraulic drives going the 1st time can be a pain in the butt. After the 1st year we have not had any trouble with them. Maybe worth 2500 for that and if you are into mapping which I think most guys are these days it makes it very easy to change population. With hydraulic drive you have to drive at least 3mph or it will not run because the hydraulics on the tractor will not run that slow. Also do you have enough hydraulic capacity on your tractor to handle the extra load? | |
