Blvd d'Espair Bowhill, Sth Aust | In terms of what to look for in a used one.... ? Pivot points ( and steering pins) have already been mentioned, but I don't think thats a particular issue for STX/TJ's, just any 4 WD tractor. I had a Steiger CR1225 that would have severe wear there in 1100 hours but the Deere 9200 had no such problems at 4,000. I'm unaware of it being an issue yet, at 1400 hrs on the TJ. The climate control has never worked worth a damn on either mine or a friend's who has a slightly older ( mine is an 05 build). The 24 speed trans is quite suitable for my application. There is no way i can guess if it is so for yours.. I have to say there always seems to be some nuisance issues with this tractor, arm rest controller failures ( meaning tractor shutdown), hydraulics that actuate with no operator input, air seat collapse, alternator failure, starter failure, and the latest one is an air con that mostly won't work at all, and nobody can find any fault.. so Ive beeen working in a balmy 92 F cab, when it's been 60 F outside. But i think for the most part Mike T likes his pretty well, so it's possibly a "luck of the dice roll" thing. |
