North Central OH | Ok seam like I am doing about the best I can, if perfectly flat could probably get up in a mile. Need to have the computer read sometime and see what the actual settings are for the multitorque, hopefully its not the cruise as that doesn't work well moving(that's another issue). This is our first big truck so its still a learning experience even a year latter.
Boost is good hooked a temporary gauge up awhile back and had ~26psi, unless that's not enough.
As far as those that say turn it way up, according to past research on this site its not possible without new pistons, 400hp is about the limit.
Edited by Trint 1/29/2015 20:55
