Posted 10/21/2014 23:28 (#4139171 - in reply to #4138949) Subject: RE: moisture on hot corn
Deep southern Illinois
We had the same tester. The temperature correction numbers increase by the same amount pher degree, and we just did the math and made a chart from 99*-130 or so, but you can continue the pattern. Now we just test with a portable mini gac that corrects for temperature.
