north central kansas | I use the Clutch Control module for my planter to control row shutoffs. I am also using the implement switches in conjunction with the Clutch Module. Now, when I am drilling wheat, I am only using the Application Rate Module for turning on Mapping. When first installed and to get going, I just unplugged the CAN on the CCM at the tee and connected the Application Module. To make things tidier and not have to switch, can I just remove that terminator and connect the Application Module CAN there? Anything I need to change in my drill or planter configurations so it does not get confused as to what module is controlling mapping? I would only have the appropriate implement switches connected for each operation.
(clutch (full).JPG)
Attachments ---------------- clutch (full).JPG (60KB - 150 downloads)
