Posted 3/3/2021 15:23 (#8870677 - in reply to #8870185) Subject: RE: Remote control On/Off Switch
Sac & Story county IA
You could use that relay in the picture to put power to the coil in the motor contactor. If it is the same voltage? If it was wired leaving the start stop buttons as they are, it would work either with buttons or remote but not be able to start with one and stop with the other or vice versa.
