EC IN | We have ran a 1225a, and now a 2425a with agleader(first integra, now Incommand 1200). At times the nickname "great pains" comes into play.
The incommand controls the hyd drive, and 3 section clutches. It takes putting a power relay on because the GP clutches require power to drive. Im not sure how that will work with trucount.
Within the screen there is the Virtual Terminal page that is used to see all the Dickey John functions. You will use this to control the split air settings and see your row monitor functions. The 1200 is nice because I can run split screen and see everything.
Speed source is through tractor GPS, and for some reason I can't get the on planter radar to run consistent so acre counters aren't accurate and populations could be slightly off what you are putting down, but within a few percent.
Agrochem out of Wabash IN is who set ours up and figured out how to make it all work. | |
