McCanna, ND | They are gold. I’ve seen the newer modes with the heavier springs, might need to look into that. I found one of my stripper plates must have shifted and was rubbing on the sprocket more then I thought. I adjusted that one and one more, both were on the sprockets where the chain was jumping. I also loosened the bolts holding the slats on and rolled the chain around, then tightened everything back up. Chain is fiddle string tight, hopefully everything I did helps and fixes the problem. | |
