Hardin County, IA | Thanks for the help Ted. After swapping multiple cables and checking power and ohms I finally decided to try swapping clutch modules. Put a different one on and it fired right up and everything worked! I would have the green light on the module but when I went to configure the clutches it would drop out or something? Very weird and frustrating! I wired it up with relays as you suggested and I got everything buttoned up, hopefully get to try it out this spring!
Thanks
Landon | |
