Schochoh Ky | You can make the job safer by installing the skab post first and concreting it in. You will have to pour the old hole when you get the building up out of the ground.Hope this helps.We were lucky with the one we raised . It was built in the late 1970s, laminated 2x6s and they were still solid . Building was 5 feet in the ground. Jacked it and dug holes and installed post in a little over a day , 4 people. Wish you luck ! It's an iffey feeling when you get it up 4 feet , promise you , you will think about quitting at 3 feet. | |
