North Central Ohio | I assume the steer command is on the latest firmware? I've had some strange issues with a few and instead of recalibrating, I like to make a whole new vehicle profile and start over. This has fixed several issues I have had. Pay special attention to getting the orientation of the ECU correct and calibrating the tilt zero step. What vehicle is this?
If a new vehicle doesn't work, look for a new ECU to swap out and try. I'm assuming your GPS is ok if it works on manual. | |
