Posted 1/22/2009 13:27 (#580274 - in reply to #580246) Subject: Re: Pro600 and Iowa cors setup
Iowa
mx270a - 1/22/2009 12:55
You have a 252 using MAX correction data? Or do you mean you have a Pro 600 connected to a 252 that is getting correction data (VRS or iMAX) from a RTN?
The 252 is not compatible with RTCM 3.1 data, which is required for processing MAX correction data. Correct?
