| The PF's give you some application possibilities, but they are still outdated units. Some parts will still be supported, but that is a matter of time. If you don't want to jump all the way to an InSight, look into an Edge. That's an entry level CAN system that will be well supported and is a bout 1/2 the price of an InSight. As far as the moisture sensore goes, there is a very good possibility that it is worn out with all those years of grain flowing over it. With the high moisture corn this last fall, you also may have had build-up on it. The elevator unit is much better. Your sensor will last longer, because grain is not constantly flowing over it, and it reduces build up for the same reasons. The end result is a better reading. | |
