| It doesn't exist.
Lots of manufacturers use AMP style connectors that you showed, but just as many want direct power to the batteries, and most of the time they use Deutsch connectors if there is a break in a wire.
Weatherpack is cheapest, Deutsch and MetriPack are both cost more.
I think it's a crapshoot.
I just build (usually) adapters to and from Weatherpack because they are the cheapest, yet extremely reliable when cycling connections, and maintaining water resistance. If the load can handle it. If not, I adjust to something heavier.
I stock Weatherpack, Deutsch DT, DTM and DTP. Yes it's expensive, but I can almost always make what I need when I need it. over 90% of the time. | |
