Buhl, Id. | First open it up and see what all was damaged. If the rod seized on the crank and broke xralan is correct that the crank can probably be cleaned up. Check for broken pieces of the case and cylinder and cam shaft. If cylinder isn't scored too bad it can be honed. I have done a lot of these with good success. Parts can be found at partstree.com. Kohler parts aren't cheap but may be worth a try to salvage your engine. | |
