Western-Central Lower Michigan | Here are some "spring loaded" push for contact switches on ebay https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2060353.m570.l131...
I wired one in for my trimble EZ Pilot. The trick is you have to solder a wire to the switch, then run a wire to a deutch connector that you buy and crimp the switch wires to.
Trimble sells a foot switch that is plug and play,, you might talk to your trimble guy on that, or maybe he would make one up with the push button for the armrest. I didnt even like the idea of a foot switch, it is loose on the floor and doing tillage it would be all over the floor of the cab.
Edited by rosiesdad 1/16/2018 11:57
