NW IL | Typically an Integra will not just update the firmware on it's on when you turn it on. You have to physically put flash drive in usb slot, select new firmwaree on the drive, and tell the Integra to update.
As far as GPS setting are concerned, go to Home> wrench> GPS (icon on lower right part of screen that looks like GPS globe).
On the GPS screen there should be options for "serial" "can" "autodetect", etc..... If set to autodetect the Integra should recognize that it is connected to a 2500.
Also...under guidance/steering, if set to "steercommand" it may be looking for 6500. Try setting it to "manual" guidance.
Edited by swenzel 12/7/2017 17:11
