East Central, Nebraska | yes. depending on age of the tractor you can either plug into diagnostic port on the nav (9 pin serial) or if the tractor is very new you will find when you take the cover off behind the seat and your turned around in the seat facing backwards off to your right is a duetsch connector. it is kind of hidden up there pretty good. this is a better way to get nmea out anyhow, though the 372 way would have worked, this will give you terrain corrected data. if it has the 9 pin serial diagnostic port you can pretty much just use a standard old computer cord to run to the agleader harness. if it is the newer style you will use the same plug you were going to on the 372. | |
