Search Forums | Classifieds (34) | Skins | Language
How to connect a Agleader RTK reciever to a Trimble FMX
welder6013
Posted 4/29/2017 13:55 (#5989658)
Subject: How to connect a Agleader RTK reciever to a Trimble FMX
Trivoli, Illinois
I have a Agleader 6500 relay with a 450mhz radio in it that i would like to hook up to my trimble fmx for RTK corrections. I am currently using a satel easy radio connected into port D on the back of the FMX to input rtk corrections. Is there a way i can use the serial port connector on the nav 2 controller to input corrections instead of using the port D on the back of the FMX. The reason i ask that is that my agleader harness on my 6500 relay has a serial port connector on its harness to use for outputting gps signal and maybe i could hook the two together?
Thank you
