68340 | Yep, real faithful about greasing everything. Just did the ramps the day before. The book shows on mine that I have all the zerks in place already. I went over this with the shop when I had it in for it's first check up the first year. You speed the cyl. way up on mine and then grease. Also need to do it on the front shive of the feederhouse if you are only cutting beans. You need to rob back the hyd hose, you use the hyd hose to lift the reel, and run the shive to high speed, grease, run back and forth a few times, and then put it back to slow speed and hook up the hyd hose again for reel lift. | |
