| Pipeline guy was out in Dad's field the other day checking depth. He told dad the line was only 10-12 inches from the surface going across his field. He then asked who owned the neighboring field cause it was only 5 inches from the surface in that field. I'm amazed that no one has hooked this thing yet. This is fairly flat ground with very little to no erosion, hard to believe that line is so close to the surface.
What exactly is the stuff going through that line? What would likely happen had someone hooked and broke the line? A big mess or worse? | |
