Posted 6/5/2006 23:40 (#17406 - in reply to #17398) Subject: RE: B&S engine ? rebuild or replace?
Brazilton KS
Sounds to me like it is probably well past rebuilding. Probably only needs a rod, crank, piston, and block.
I'm having a hard time invisioning how the valves could be hitting the piston, though.
Would be best if you could figure out a way to run it with a single output shaft, then you would be open to use a fake Honda...lots better OHV engine for equal or less money then the flathead BS.
