Posted 3/10/2012 17:39 (#2279619 - in reply to #2279503) Subject: Re: How to bleed the fuel on a 3406A to get the motor to start?
68340
Thanks. I could not get the lines to crack at the head. It seemed like the line wanted to twist with the nut and I sure did not want to break a line. So I cracked some of the lines coming out of the injector pump and could get fuel to come out there. Charged the batteries and then the angles came down from heaven as started the motor as I cranked it.
