NC IA | +2 KTA, I agree with him I 'd also say you had a GOOD day in the shop. Much better now then when it spits it all out with a storm comin and its 110* out. BTDT have the t-shirt.
Completely gut total shaker system including the hex shaft. Inspect the cams, hubs, replace ALL bearings with USA timken/fafnirs, Look everything over for cracks, replace shaker needle bearings/hangars, make sure you put in the HD German shaker bushings not the junk Mexican ones. The shortcuts you take on the shaker system all lead to dead ends. Do it right and do it once, my shaker makeover has over 1500 sep hrs on it and still going strong. I'm convinced many red combine shakers weren't assembled right at the factory, and most of the time when they have problems they are "band-aided" back together and the root problems are often ignored or overlooked. Good luck! | |
