Posted 5/31/2006 16:35 (#16165 - in reply to #15985) Subject: Re: Dodge cummins
I have three 91/92s, on two of them I have had to put a new wire spade on the rotary fuel pump. Pop your hood you will see where two wires go to the same spot on the pump, it will be corroded and loose, clean it up and you are good to go again.
