N.E. Iowa | <p>Drop the belts, electric wire and 2 bolts on each side, remove pin from cyl. and pull it out. I cut the floor back to the cross brace and replace that section. I just bend it at a angle where the hump stops and weld it in. You don't need the hump. I think the piece I make is 22 inches deep and overlap on top 1 inch</p><p> </p><p>I should have said where the hump stops on the back side of the piece you cut out. I don't put a hump in the replacement piece.</p>
Edited by chevyman2995 7/20/2011 22:49
