What is a good common male and female connector to use on 12VDC equiptment in tractor?
Threadkiller
Posted 3/9/2011 10:47 (#1659970 - in reply to #1659913)
Subject: RE: What is a good common male and female connector to use on 12VDC equiptment in tractor?
SE North Dakota
I was going to recommend a "weather-pack" connector like this:
http://www.mcmaster.com/#multipole-connectors/=bcxo8b
-but your amp needs may be too great for them. Maybe someone knows of a higher amperage rated connector that uses this sort of a seal to keep out moisture?
