Dietrich, Idaho and Mountain Home, Idaho | Pro Till,
Something I found on one of our tractors that I have our raven smartsteer on that was kind of hard to get right(get all the wiggles out) was to put in the measurement of the actual wheelbase for the antenna fore/aft. What I mean is that on that tractor(JD 2840 2wd) the Wheelbase measurement is 97" so instead of putting in the actual measurement of how far forward that antenna is from the rear axle(47") I put in 97" to make it think the antenna was over the front steering axle. Worked like a charm. Do you think that would work with the ontrac2? |
