| my reccommendation is have your dealer do a radio survey of your fields. a good dealer that is serious about the $20k+ sale will do this. this will require him to set up a mobile base and physically drive to the low areas. to see if you are a good canidate for RTK. as far as working through brush yeah i think aslong as it wasn't too thick and maybe hasn't had folage yet. you'd probably be ok remember, the distance from the base will determine how much/many obstacles the signal will make it through. | |
